I recently purchased two new Samsung 712n's and have them connected to a saphire radeon 9800; the primary display is connected to the VGA out, secondary on the DVI via a dvi-to-vga adapter.
I have a strange problem where the 2nd display has a slight but noticeable blue hue to it.
I have moved the monitors to three different machines and both worked perfectly. I have also bought a brand new dvi-to-vga adapter just incase the one I had crapped out; no luck. On a long shot I tried all the various utilities that samsung provided, but they did not remedy the situation. As a temporary fix I have resorted to adjusting the red and green up on the 2nd display to compensate for blue hue, and despite it helping it's still noticeable.
I have found that cranking the brightness to full just about fixes the problem but it becomes somewhat uncomfortable to look at after awhile. It probably just bleaches out the image more than fixes the problem, me thinks.
Has anybody had this happen before? More importantly does anybody know how to fix this?
Could my video card be crapping out on me or is this some quirk coming from connecting a vga monitor to a dvi output?
Thanks for any input.
