$100
Been sitting new in box for months ... I have too many cases and need to get rid of this one.
It is large and heavy, so I can't ship it unless you want to pony up the $50-60 that both Fedex and UPS want to ship this bulky item.
Description:
# Fully-modular chassis
# Open-frame mesh panel construction
# AirMounting HDD suspension mount system for up to 6 HDDs
# Maximum CPU cooler height: 150 mm with optional side fan installed, 160 mm without
# 11 drive bays:
- 6 x internal 3.5" HDDs
- 3 x external 5.25" HDDs
- 2 x internal bottom-mounted 2.5" SSD bay
# Advanced cooling system - up to 15 fans
Standard fans:
- 2 x front variable-speed 120 mm blue LED fans with stepless control knobs
- 1 x rear 120 mm blue LED fan
- 2 x side 120 mm blue LED fans for graphics cards cooling
Optional fans:
- 2 x 120 mm fan for CPU and memory cooling
- 6 x 120 mm side drive bay fan
- 2 x 120 mm top fan
Water cooling support:
- Top water cooling radiator fitting
- Rear water cooling grommets
# 8 expansion slots for triple graphics-card configurations
# Maximum graphics card size: 16" / 406 mm
# Front ports:
- 1 x USB 3.0
- 2 x USB 2.0
- Audio In and Out
# Motherboards: Mini-ITX, microATX, Standard ATX
# Power supply not included
# Unit Dimensions:
- 20.4" (H) x 8.7" (W) x 19.3" (D)
- 518 mm (H) x 222 mm (W) x 4906 mm (D)
# Package Dimensions:
- 23.2" (H) x 11.3" (W) x 22.8" (D)
- 590 mm (H) x 288 mm (W) x 580 mm (D)
# Weight::
- Net: 20.3 lb / 9.2 kg
- Gross: 24 lb / 11 kg
Local pickup only (Zip 98052) Can meet in Bellevue, Redmond, Woodinville, or Issaquah.
Description:
# 11 drive bays:
Standard fans:
Optional fans:
# Front ports:
- 1 x USB 3.0
- 2 x USB 2.0
- Audio In and Out
# Unit Dimensions:
# Weight::
