I've recently built up an HTPC and have used Crim's very helpful guide in the stickies but started to hit a couple of problems. Been googling a lot to try and find a solution but not found one yet.
First question is: How do you get PowerDVD to play Blu-ray rips (both in folder and mkv format) from Media Browser. I have it in the external player config, it launches but then just sits there at the start screen waiting for me to navigate to the movie under the video tab?
Second question, what is the preffered software for mkv encoding? I tried DVDfab Blu-ray to MKV on the .264 setting, worked fine but puts a DVDfab logo in the top right corner. I want to be able to take the folder rips (50Gb) on the hard drive down to (12Gb). Problem i encountered is that MC/B plays the mkv rip at double speed, while PowerDVD plays everything normal, hence the first question. Think the double speed playback might be codec related, but not sure how to successfully remove or disable certain codecs - or even how to determine which ones MC is using.
I have:
ac3 filter
ffdshow
Haali Media Splitter x64
CCCP codec pack
I have tried TMT3 but not WinDVD yet. PowerDVD is 10 Ultra. I play DVDs through MB directly but the Blu-rays are becoming a headache, i thought Media Center could now play the bluray from a folder structure, but I get the "cannot play file blah blah", hence trying the mkv route, but thats double speed so i'm back to an external player.
Really appreciate any suggestions, thanks
I have:
ac3 filter
ffdshow
CCCP codec pack
