Blu-Ray movie gives error
HAL_404
just got a Blu-ray brand new and tried to play it and got the following error using PowerDVD 16. All other Blu-rays older, same year or newer all play no problem. I ran Cyberlink's Advisor program and it says all is well with my hardware. Anything you know I can check? Only setting I have in question is in BIOS: BIOS Mode which is set to CSM by defaut instead of UEFI. THanks for any help.
Vizio E55-E1 TV
LG Blu-Ray Drive model UH12NS40
ASUS ROG Strix GTX 1660 Ti Advanced GPU
Windows 10 Home
make sure your powerdvd is up to date and that your gpu drivers are up to date and whql'd.
As long as it's not UHD disc which would require an Intel CPU then maybe try a new cable. I can confirm the monitor is capable as seen below with PowerDVD15.
thanks for all the info everyone ... I play around with it and see what happens. There is a firmware update for it but it says in the text guide No OEM drives and of coarse that's what mine is. NP I have the DVD version of the blu-ray that wont run :)
