This isn't on a computer, but I know some guys here can help
I have a marshall amp, and the fan on it was really loud. twas a little 50x50x10mm fan, nothing fancy.
I have a 50x50x15mm fan I replaced it with. the difference in the fans are one is a 0.18A fan, the one I put in is a 0.16A fan. both dc12v fans. I put the fan connector from the stock fan on the one I put in (cheap linksys fan but works), and made sure to shrink tube the cables so there isn't any wires gone wild to short anything.
I put it back together and the fuse blows. grr. the only thing I did was unplug the fan, clip the wires and connect them to the right wire (positive to positive, ground to ground) and plug it in.
Instant blown fuse. I don't think I shorted anything as I didn't touch the main PCB or any auxilary PCB's while I was in there. the fans are relatively closely relate in their amp/wattage. Any suggestions?
