UT-Jackal said:Just finished up putting in a 120mm fan in the top of my bro's computer out of bordom. Whatcha think?
[/IMG]![]()
JEEVES/whohasmyname? said:its nice, but the screws realy ruin it imo. should of tried to stealth the screws from the underside. But other than that clean cut. What did you use to do it?
JEEVSE
arock1_3 said:Nice and clean job, just change the screws.
Shadowspawn said:The blowhole doesn't need a fan guard...the blades are turning the wrong way. Try it sometime. Stick your finger into a running blowhole...you won't be hurt. Besides, guards make noise. My current project will have 6 120mm fans, none with guards. Too loud.
Nice job on the hole. Now cover up the sticker.![]()
