So I was thinking about the best, mostly no-hassle way of putting in a blowhole (or 2, preperation for a 2x120 rad later on) with me not having a jigsaw, or a steady hand.
So the tools I have to use, dremel with all assortments of cutting wheels, buffing wheels, sanders, the whole shebang.. and a drill.
Well I came up with this idea, i'd trace the fan and where the screw mounts are onto some masking tape ontop of the case, and then mark out a bunch of dots where I would drill through. I would end up with a ultra-swiss cheese like top with plenty of holes for the out-take, and the case would act also as a grill for the fans. Anyone made a blow hole like this? Just drill the 4 screw holes and a bunch of small holes for the air flow.
Later on, (like.. 5 months at the very least) for the rad, I would just dremel out a rectangle and place a radgrill on top, but I don't need to do that right now.
