AuroraProject
- Dec 13, 2004
Can I mount a DD TDX block sideways instead of vertical? This would aid in hose routing. Here's what I mean, in the pic below you see the TDX mounted normally, and the chipset block below it. I can't make the bend from the TDX out to either one of the chipset nozzles without kinking the hose.
But, if I mount the TDX to the side, as shown below, I can make the connection with no hose kinking.
Would I be ok with the second setup? I will be adding a w/c video card at a later date, so the arrangement may change then.
