Blew a motherboard, Please help
tdowning
I'm posting this here because there is no "Troubleshooting" category
built a new computer about two weeks ago:
Gigabyte K8NSNXP-939 motherboard
2x 256 MB 400 MHz Crucial Ram
200 GB Seagate SATA HDD
Athlon 64 3500+ CPU, (socket 939) (Retail Package)
Antec Sonata case, (came with True 380S power supply)
Radeon 9600 Pro Video card (OEM)
I looked at the pinout diagrams for the USB headers on the motherboard, and they appeared to be the same, (one refered to the ports as 1 and 2, and the other as A and B)
all worked well until I connected a Sandisk Image-mate MMC card reader to one of the front mounted USB ports, and everything went to pot.
first of all, both mice stopped working, (Both USB, old MS Explorer Optical, and a Gyration wireless pointer.)
I rebooted a couple of times, and never got the mice working again. I shut the machine to attempt a cold-boot, but was never able to get the machine up again after that.
another funny thing started happening, I saw this strange pattern of red pixels on the display, (Sony 19" LCD connected via DVI, and it kept blinking on and off, (Like the computer was going into standby)) I had seen this happen once or twice before, but it cleared up after I rebooted, or managed to get into windows and chance the display resolution to 800x600, and then back to 1280x1024
I took the motherboard RAM and CPU to a local screwdriver shop where they tested the three components, and found that the motherboard was bad.
A closer inspection of the case and a comparison with the bracket that came with the motherboard using a sacrificed USB cable and an ohmmeter has revealed:
1. motherboard bracket has 2 wires each in 4 colors, red, (+5V) Green, white, (the two data wires, + and - and black, which connects to the ground and shielding of both cables, which are connected to each other.
Case's connector has 9 wires in all different colors, the +5V wires are connected in parallel, and the ground and shielding are connected to three pins, (the two that correspond to the black wires on the motherboard bracket, and the one that is unused on the motherboard bracket.
whatever happened also killed the card reader as well.
Do I need to send the case back as well?
