Bleeding/Pentosin/Distiled Water questios
Vlad_13
Here is my loop:
D5>Black Ice GT Stealth 240>TDX>MAZE4 (chipset)>Black Ice GT Stealth 120>MAZE4 (GPU)>Micr Res> and back to D5
and herei have Pentosin and PT Nuke
1st: how much of pentosin i need to put in my loop, it's 7/16" tubing I KNOW that it has to be 5-10% but if you guys did this, how much of a bottle did you put there, half? 1/4th? full?:eek:
2nd: question on the PT Nuke, i believe 2-3 drops should be enough? or 1-2?
3rd: how do i do fill the water properly or how do i do the bleeding properly? I was thinking submerging Micro Res in to the bucket of distiled water and then just sucking in the water from the GPU (last stop) tube? and as soon as i drink some water i would clamp the tube and put it on the res "out" fitting?
Thanks for your help and time :)
It really doesn't matter how much Pentosin you put in as long as you're not dumping the whole bottle. The amount depends on the amount of water held in your loop. I'd honestly just go with the amount that gives you the color you want.
Again with PT nuke, 1-3 drops is fine and won't kill ya if you add too much.
The problem with your bleeding is that your res is not the highest point of your system. You need to temporarily stretch it so that its the absolute highest point of your loop. You could lie the system down on its side making it easier to keep the res at the highest point until its fully bled.
If i put my pc on the side which i will and start filling in the res with dist water, does that guarantees me that there will be no air left in the loop?
Or my method on sucking on the tube would work better?
Maybe i should do both :p
Well, I suppose you could suck the liquid in from a bucket... but first off, thats just gross, and secondly, it will still leasve air in the system since you need to attatch both ends of the hose again.
Bucket is clean, it's watter... wtf you think it is that it is gross, I'm sorry if i express my self in a wrong way but my English is limited and i don't care on how or what people might think cuz apparently her in America word "sucking" only corresponds to one thing.......
Grow up.....
He said its gross because you are potentially drinking toxic antifreeze and biocide.
By the way, you do not need your res to be at the highest point in the loop, but it helps. Rocking the case for 5 minutes every hour for 24 hours works well too. Regarding the concentration of liquids, if you don't have any aluminum in your loop, buy a gallon jug of distilled water, and pour the pentosin in. Use 3 drops of biocide, 4 if in direct sunlight. Now I recomend using the DD-Fill Syringe to get the water from the gallon jug to the resovoir, and you may have to cut off the top to get the stuff at the bottom. It is what I did, works well as far as I can tell (pretty sure my fluid isn't causing the 2-3c above ambient idle temps...).
Grow up.....
Easy now. Making insulting generalizations about an entire country (which I am a proud citizen of) is not a good way to win friends. I don't think he was trying to be vulgar. Siphoning fluids by mouth is generally not a pleasant thing to do. I didn't pick up on the fact that you were going to have only water in the bucket either. I thought you wanted to siphon your water/Pentosin/PT mixture. That WOULD be gross!
Anyway, by doing this you are substituting your mouth for the pump and you will probably still have air in your lines. Air will migrate to the highest point in your loop because it is less dense than the liquid. If your res is the the highest point, the air will migrate to the top of it and you can bleed it. Also, if you keep your res at the highest point in your loop, you will insure that the air won't dissolve back into the fluid.
BTW please do not take this the wrong way as I am trying to be helpful. Since your English is limited, this site may be of use if your native language is included:
http://babelfish.altavista.com/
The translations are not perfect, but they are decent for a web tool.
That would definitly be what I was reffering to... if you want to get a mouthful of antifreeze, then by all means, do it. But with a mouth like yours, doesnt seem like it could get any dirtier in there... so go ahead "suck" away.
Now tell me how stupid do I have to be to drink antifreeze that contains Ethylene Glycol which is TOXIC and "PT_Nuke" that contains or is Copper (II) sulfate which is TOXIC too. Why?
You know those things i could add later when my bleeding is all done, thats why in reservoirs there is a little cap so you could pure/add stuff :p
But anyway, thanks for your help, I know what i have to do and what NOT to do (drink antifreeze and biocide :p )
If you are going to just open up your reservior later and add the chemicals, why are you even asking this question?? Just turn your PC on its side, take the tank and hold it upright, and add the fluid. This way it is above the rest of the system, and will get most of the air out. There will need to be some settling, but it will get most of it out.
It seems like am aweful lot of work to go through if you are just going to open up the tank later anyways. You can also pre-mix your fluids for the right parts per ounce.
Next time, be more clear. If your english is good enough for you to be a tough guy, its good enough for you to say what you mean, more understandably, the first time.
Simplest way to bleed your system is to unscrew your reservoir, tip your case over so that it's lying on the mother board tray side. Use something to prop the reservoir as high as you can and then run your loop. Fill water at least 2/3 of the reservoir. You'll be good in no time.
Doing that right now :D
I was asking this question because i still dont know how much would be 10-5% of pentosin to my loop, i thought maybe by showing pics of my loop some one would approximately tell me "add this much and this much of antifreeze".
And i wasn't sure how to do a proper bleeding, be fore i had a DD 5.24 bay reservoir and i didn't do bleeding at all, i ended up with air in the pump to the point that water was barely moving trough the loop, I didn't even know :(
Spell check is my best friend :D
Add 1/4 of the bottle and keep adding a bit more until you see the slight blue tint that most users have when they use Pentosin UV mix.
How long do i have to bleed this thing? :confused: I tilted comp from side to standing positions, and again i put on its side. It's standing on the side again with res on carbon box above everything.
That's what sucks about black tubing ;) . I'd run it overnight just to test it for leaks again anyways. Bleed it 24 hours with res cap off. You'll be fine in the morning. I'd add the Pentosin now if you haven't yet since adding Pentosin usually adds a small mount of air bubbles.
Cap off? O crap, it's on :p
So 24 hours huh... uyyy :( that's a lot of time, been sitting without gaming rig for a month already, i guess 24 hours will not kill me...
Whenever you bleed a loop, always keep the cap off. Makes life a lot easier. You can still do it with the cap on, but it takes more time.
