blah temp case for the system
lord_tris
haha and the only thing that i had to modifiy was the rear i/o panel
and yes there is lots of double sided tape being useing and a magic:the gathering box holding the rad up cause its to heavy
Crumbs, u really should try reconfigure that wc setup. Why did you place the pump right at the top ? Here's a pic of mine, perhaps you could try do something similar :).
Dont see why you couldnt try set it up similar to this? Or perhaps work it so the rad is right at the front? That just does not look very stable :eek:
PS: Is that cat real :confused: , looks like its stuffed :eek: .
like the title says its a temp case till i get done modding the aria which will be like another 2-3 weeks of moding or so.
and yes the kittie is real her name is Mystie
