It should do pretty well depending on what CPU and video cards and how much you OC them.bladeiai said:do you think a BIP 2 would be enough to cool the 2 video cards and a cpu?
yes i am sure...be sure to have a good pump, good head.bladeiai said:do you think a BIP 2 would be enough to cool the 2 video cards and a cpu?
bladeiai said:I currently have a Hydor L35, but I am planning on getting a Danger Den CSP-MAG 12 Volt Pump or a Danger Den DDC-12V because the hydor is very loud and I am trying to build a very quiet pc, does anyone know which of those would perform better and which would be quieter?(of the 2 I am looking to buy I mean)
get the ddc...you have a lot of blocks you will need the head.....bladeiai said:BIP2 it is then.... has anyone had this pump?
http://www.dangerdenstore.com/product.php?productid=178&cat=23&page=1
I just cut the holes in my new case for the grill to cover the bip2 yay
bladeiai said:what? isnt that what I asked?
bladeiai said:is there a difference between the d4 and d5 besides the adjustable switch thingy?
bladeiai said:ok... cool thanks
also while Im asking, I took the little nozzle thingy out of my tdx the last time around, does it perform better with it in, and if so which one?
Bugsmasher said:It performs better with it in. One of the keys for the water passing through the block to absorb heat is turbulence. That nozzle focuses the stream of water into a higher speed impact with the inner surface of the water block which creates more turbulence. This in turn allows the water to carry more heat away from the waterblock.
Short form- its better with the nozzle in![]()
