ikjadoon
- Jun 21, 2006
HP's new Blackbird 002 is setting some records, with this configuration for only $5,500:
Intel® Core 2 Extreme QX6850 3.0GHZ + Additional Performance Tuning
Dual NVIDIA GeForce 8800 Ultra with NVIDIA SLI
CPU & dual GPU Liquid Cooling
2 GB 800 MHz CORSAIR PC2-6400 DDR2 SDRAM
1 160GB 10,000 rpm SATA (Western Digital Raptor)
1 500GB 7200 rpm SATA
Voodoo Razer Gaming Mouse & Keyboard
They have reportedly gotten that quad-core to 3.67GHz. Have a read:
"Every HP Blackbird 002 PC ships with a performance BIOS, allowing for comprehensive customization by the end user and making it a natural extension of Voodoo's open-system legacy. Although your Blackbird is built and pre-tuned in a Voodoo DNA facility in Calgary, Alberta, we leave the BIOS open with no proprietary barriers. The memory speed is adjustable, and you can tweak more than a dozen aspects of the system memory frequencies independently of the CPU's FSB, including the CAS Latency, Async Latency, and Command Per Clock. Voltage settings can be adjusted in nine different areas, and a hardware monitor constantly checks the voltage, temperature, and fan speed, warning you if you're putting any part of the system at risk. Set a target temperature for each zone on the motherboard, and the fan controller will maintain it. Once you have your BIOS settings customized, you can save them as a profile for quick configuration changes"
First time I've seen this kind of openness from a boutique/mass-market company. It is rigs like this when I wish Consumer was still around. I would love for them to tear this thing apart (in a good way). *Hint*Hint*
Anyways, just wanted to give you guys a heads up on this beast of a machine that will be trouncing records and keeping them for quite some time to come.
~Ibrahim~
~Ibrahim~
