Wait.. so that was the question... Where to buy black spray paint? Have you ever been outside of your house before and even walked in a store to see the merchandise they carry?
Dyed my Plexwriter black & it matches my case better than the black NEC drive.
A good application of dye will last a good while. Used spray dye to color the seats
in my '69 GTO black back in 1992. They still look good.
YepDye is also great for painting the wires in your case, so they're all the same colour
That too. Another option for wires is liquid electrical tape. A friend coated all his wires with that, looks good. Only thing is, that stuff puts out HELLA fumes.YepDye is also great for painting the wires in your case, so they're all the same colour
Ack! That offends every fiber of my electrician-in-training being... I'm gonna come wire your house with all black wires too.![]()
Yeah, you are more than welcome to run some all black wiring in my new detached garage.Bring it on![]()
Ok, fuck I painted my drives' faceplate, and now it's like glued together.
. Keep in mind just because its dry to the touch does not mean its not tacky, if you do not allow the paint to throughly dry the drive the tray cover can stick to the face plate.
