Black Sony Trinitrons, $119.99 at Surplus Computers
Tube Type: - CRT 21inch SONY Trinitron FD (Flat Display)
Dot Pitch: - 0.24 mm Aperture Grill Pitch
Viewable Size: - 19.8inch
HSCAN / VSCAN: - 30 kHz to 121 kHz / 50 Hz to 160 Hz
Refresh Rate - Max/Recommended: - 85Hz / 85Hz
Resolution - MAX/Recommended: - 1920X1440 / 1280X1024, 1600x1200
Type: - MultiScan, Plug and Play
Platforms: - PC and MAC
Signal Input: - 15-pin D-sub (standard VGA plug) and DVI (Digital Video Interface).
Dimensions: - 19.8 in. (W) x 19.6 in. (H) x 20.0 in (D)
Condition Refurbished
Warranty 90 Days
DVI input, that's awesome!! If I didn't have 3 LCD's I'd be on this in a second!
I know, if I hadnt wasted 150 on a new 17inch CTX, I would be on that monitor like ugly on a monkeys butt!
184$ to california. ouch, thats a bit off the 119$ price. 50$ for shipping? thats a little high, i shipped my 21" for 35$.
still, a good deal for those still looking at CRT's. myself, i'd rather spend the extra 150$ for a 19" LCD.
LOL That's the same monitor I use @ work.
The dual inputs are nice on this bad boy.
1600x1200 @ 85hz no problem
chomsky said:
The lowest I found on a new one was $230 with free shipping here: http://www.azatek.com/details.asp?iid=524
new or used, I'm still tempted
Not new
condition: Grade-A, Excellent Cosmetic and Working condition.
Off Lease Inventory. Used. VGA and Power cables included
But still one serious monitor for the price. I'd hop on it in a heartbeat if i needed one.
d00ds
I started using this type of monitor ~3 years ago. They all had a few years of service on them, but they're great monitors.
You may wana check out your local Fry's Electronics too.
I got a 22" NEC CRT w/ DVI inputs for $159 (used of course).
the gf would kill meh if I got another monitor.
1920x1440 isn't clear. I had one of those. The horizontal resolution of the grill is 1690 with a 0.24mm dot pitch (20" visible).
I'd throw down on two and sell my current 19' monitor, but then again I wonder if my desk could stand up to the weight. Do I want to test it? It's an IKEA Jerker, which should be sturdy enough.....
edit
And my 9600XT has dual DVI.... damn this is tempting. I wish they had DVI cables up on their site but I don't see them anywhere.
Convergence might be bad on these monitors.. I have a dell trinitroy p990, convergence is bearable on 1024 but the red/yellow lines are noticable on the sides, and 1600 is unusably blurry, even though the refresh @85hz is great.
You must have a bad tube. I bought an off-lease P991 several years ago and to this dayit's the best looking CRT I've *ever* seen, and I run it at 1600x1200. The Sony FD tube is awesome. OTOH I have a 22" Viewsonic at work with the Mitsubishi FD tube and it's not all that great -- my 19" Dell looks much better at 1600x1200 than the 22" Viewsonic and it's brand-new.
I have a P-202 IBM Trinitron...running 1152x864 @ 100hz...
mine has the 15 pin D-sub and the Sun connection....would love to go DVI though.
You guys don't realize how badass IBM trinitron montors are. I put down 550 bucks for a Dell 2001FP to replace the P-202, but shipped it back because the image quality for applications and gaming is so much better. If my old reliable P-202 ever dies, I will buy one of these to replace it. Its not lan friendly at all (65+ LBS!!!)...but fantastic for the gaming rig that never moves.
I'm so weak! :D
I just couldn't resist. $174.24 shipped.
It'll be an awesome upgrade from my current 17" craptacular Gateway monitor...
I'll let you know if there's anything weird when it gets here. Their profile @ resellerratings.com was fine, so hopefully no problems.
Orwick Alefgard
And when did you ship your 21"? and with whom did you ship. Additionally, did you factor in the cost of the box itself, or your time to take it to the shipping location when you figured out your shipping charge? When will people figure out that s&h has TWO letters, which means TWO things.
shipping [ups's charge] and HANDLING [the labor time of the person physically mailing it out]
just FYI, using the DVI connector just means that it is going to use the analog pins on the DVI (they're the 5 pins off to one side in a + pattern) so image quality won't be any better than from using the D-sub input.
Heck of a deal for anyone looking for a big monitor, though. If I wasn't thinking about going LCD, I'd probably get one of these babys. Oh yeah, if I had the money, too. :p
Damit ya beat me too it. Still, with dvi there is no shielding between wires ( think printer cable), i wonder if the rgb runs are each shielded, then again they share 1 ground... Eh works fine on my buddies p260
F'ing christ. I want this. $139.99 with shipping? Sigh. If only I didn't crash a car against a tree 2 weeks ago, I would've bought this (and that would make it my 3rd 21" monitor on a desk). :eek:
-J.
I've had really bad luck with refurb monitors. So I decided to go with a Viewsonic 20.1 inch LCD instead.
I have had good performance out of my IBM refurb. I have had brand new samsungs, Dell, viewsonic, all have broke but my 4+ year old IBM/Sony tube refurb is still ticking. I may have to pick one of these up for an upgrade. ;) Thanks for linkage!!!
Why did I buy my 997 DF two months ago for $50 more than this!!!!!!!! :mad:
Anyone who thinks they want to stay CRT & upgrade from a plain old 17" CRT, go for it, you will love the higher resolutions & refresh rates.
If only, if only I had waited two more months :rolleyes:
Anyone have a weight on this sucker? I heard 65+ lbs, and that might kill my cheap-o walmart desk... but its temping cause im on an old dell mon that came with an optliplex first rev waaaaaaaaaaay back when... (450mhz pIII powa)
Dimensions and Weight Weight70.55 lbs
lol ouch... so debating whether it will kill my crapy wali-mart desk or not...
It's a good deal if you live in the San Jose/Bay Area and can pick it up at the store. I bought a couple monitors from these guys before I went to school.
Yeah, I just bought a 997DF about a month ago. I just bought the ebay linkage.
Anybody want a slightly used 997DF? :D
zasquatch said:
double ugh!
must...find...a way to....resist
I couldnt muster the strength to resist. Hey, if you dont LOVE it, you can always sell it on eBay :D
Pricewatch also has this monitor for cheap. When it first came out it was over $1000. Browsing the [H]ot|DEALS forum is starting to get to be an expensive habit. :cool:
superlyduper said:
how would you pack and ship such a huge monitor?
Its called trash bags and foam. Get really big box, put trashbag in. Fill trash bag with 2 part foam. Place monitor in box before foam drys in bag. Now put trash bags around monitor and fill them with foam. Close lid. Walla, perfect pack. At least thats how all my reconditioned babies came. We are sol if they wrap them in newspaper and pop corn.
must..... resist, these are great monitors, no experiance with the refurbished market, but i think ill take a shot,
-P
ive gotten two refurbished monitors. one was "okay" the other was pretty good. but this monitor price is very good that even if u got an "okay" one, it'd still look good anyway and you're getting a deal. by the way, you think 70 lbs is nothing? i got a 22" thats 90+ lb.. freakin' sony. :eek:
-J.
I used to work at compusa and got a deal on a 21" sony E540 they were just going to throw out still had the 3 year warrenty on it (parts AND labor) got sony to replace dead moniter with a refrubisd one... and now here we are almost 3 years later and the moniter is starting to get brighter and brighter, I have to keep adjusting the brightness level down by 1 point every month or so, if I hadent crashed my car and tore up the rear wheel and axle needing 500 bux in parts and labor, (and that was family discount) I would buy that black one in a heartbeat, damn mabey there still there in a month or so.
