Black screen = faulty hardware?
RumpRoast
I'm having a little issue since I rebuilt my pc. I upgraded from a Shuttle with a socket A 3000xp to a 939 4000 San Diego with a Soltek K8T-Pro motherboard that I bought here from the for sale forum. I recycled most of my hardware from the shuttle; hard drive, vid card and memory.
The problem I'm having is my pc will go black screen on me sometimes during gaming and now it will do that will surfing the internet. Before, prior to the black screen during gaming the screen will freeze and the sound will loop until I have to manually hit rest button since Alt+ tab does not work. Now, it will all of a sudden black screen and for a second my monitor will flash in the middle of the screen. It's hard to explain what it looks like but the best way to explain it is it looks like a star exploding in space...the shape of it looks like Saturn? the pc is still on but my monitor acts like it has no signal. When the pc is on the monitor button is green when it happens the button is orange. At first, I thought it might be my vid card on it's last leg so I bought a temporary fix, another 120m fan to attach to the hard drive case to blow directly at it and reapplied Artic Silver but no dice. I also noticed that the top of my monitor is hot.
I'm at a lost right now as this is happening on a consistant basis now. if it is indeed my vid card overheating than I would rather buy a new vid card and upgrade to PCI E rather than buy a n aftermarket fan + ram sinks. I recycled most of my hardware from my old pc and did not experienced any of these sysmptoms when I was running the suttle until a few weeks ago. Any suggestions would be greatly appreciated.
RumpRoast
Yes I did, I'm currently using XP pro. Since I switched motherboard and cpu I didn't think that the pc would post without a reinstall, right?
What throws me off is the fact it would happen 5 minutes after i hop on the pc to browse the forums where as before it would happen after an hour of gaming.
1. Try a different monitor to make sure its not the problem. ( Probably not the case, but doesnt hurt to check. )
2. Did you reuse the PSU? What kind of PSU do you have?
3. Sounds like a memory problem. Double check the timings and RAM voltages in the BIOS of your new motherboard. Make sure they are all set to factory spec. Run memtest to make sure there are no RAM problems.
4. Post back and let us know what happens.
I'll borrow my buddy's monitor he has sitting around
The PSU I'm using now is a 380w True Power that came with the Sonata case i picked up a few months back at Circuit City
Not sure, but it's worth a try. I'll do that when I get home from work. Will it help if I post results from CPU-Z?
