Black Ice Xtreme III
unless u have crazy fans w/like 90+ cfm then jsut get the pro.
What will be the configuration you were thinking of getting, or already have, to use with this rad? (Pump, blocks, etc.)
the BIX only starts to outperform the BIP with fans of 100+ CFM, or maybe that's just the ThermoChill radiators, I can't remember. If you're using fans with anything less, get the BIP. Or get a Thermochill PA 120.2
I already have a 12v DD pump and CPU and chipset waterblocks along with a mountain mods case. I'm ditching the resevoir and going with a fillport. I have 6 fans for pushing and pulling to mount on the radiator.
What screws should I use to mount the fans to the radiator? Fan screws seem too large.
The radiator should have come with self-tapping fan screws.
