well, i finally got my two black ice extremes.. but im having trouble figuring out how to mount these bad boys.. should i use the screws that they provided me? or use my fan screws that came with the case? i need to mount a fan onto the radiator then mount it onto the case.. i want to later on mount another fan into push/pull config so i dont want to put the screw that they provided because i want to be able to use the same screws for the fan.. please help.. i have everything but i cannot install it..
