I believe black crush is exactly what i am running into with my new monitor. You cant see the details in the different shades of black. Instead of seeing individual details in a shadow, for example, you see the shadow as one lump of solid black. I have been able to fix this by tweaking my color settings in the nvidia control panel, but those settings don't take in my 3D games unfortunately.
The link below is a test image. If you are experiencing black crush, the entire first row and maybe the first couple of the second row will all be the same darkness of black.
http://www.lagom.nl/lcd-test/black.php
It's basically an inherent effect (or flaw if you will) of VA panel technology whereby black and dark shades near to black at the centre if the screen (when viewing the monitor dead on), will "crush" together, in other words you lose a lot of details usually in shadows. If you move your head horizontally to the size, the detail will reappear or the blacks get lighter. Also if viewing the monitor straight on, one or both sides can appear brighter.
You can see it happening here: http://img101.imageshack.us/img101/5321/colorshiting.jpg (taken from this review).
ToastyX has also posted some great examples of black crush or gamma shifting on these forums, i.e. here or here. The example ToastyX uses (here) should be completely uniform all the way across, but it's not due to the gamma shift.
You can see it in motion and more visibly in this video: http://www.youtube.com/watch?v=sC7EozTCGSQ. In the video you should be able to notice that you lose detail when the viewing head on, but see more (i.e the folds in his jacket and parts of his cheek) when viewing from the side.
Note, black crush can also quite commonly mean what KenG10 stated, however no matter what angle you look at the monitor, the blacks are always crushed. Black crush in context to VA panels (or the less confusing term gamma/colour shift) is something different and only occurs when you're viewing at the VA monitor at certain angles.
You can easily test for black crush with this image: http://www.toastyx.net/va-test.png (Similar to the 2nd Youtube video I added).
It's an image with a black background and the word TEST written across it in a very dark shade of grey. Just open that image and view it so that it covers the entire width of your monitor and see if you can still read the text when viewing the monitor dead on (which you probably can't on a VA monitor) or at an angle to the side (which you should).
It is important to note that these issues vary in severity from one panel model to another. They are not all the same.
Gamma shift means that the same color will very by the angle you are looking at it. So if you put up an all violet screen. It will look like a red to violet starburst or radial graident from the center to the outside of the screen.
VA panels are known to have the slowest response time as well. Their strengths are that there is no white glow like you will find on any TN or IPS panel that does not have a ATW polarizer, and most of them do not have one.
If you are nearsighted like I am, then a good VA panel might make sense, because IPS white glow is a bigger problem when you look close to the screen. White glow is a problem on larger panels, especially the 30" dudes. Samsung makes a 30" S-PVA panel, the 305T plus, but they do not holdup over time and there have been numerious complaints about poor support.
White glow is a white haze that fades in from the outer edge of the panel, especially when viewed from an angle.
The bottom line is that all panel types have some kind draw back, with the exception of the NEC 2490WUXi and they are no longer available.
Dave
I can see the text appear more vividly at an extreme side angle, otherwise it's just hard to see.
Yea, I took a chance on 3x U2311Hs and got duds imo... so I'm done playing the lottery. I plan on picking up a couple $500-600 Sony or Samsung LCD TVs as I'm pretty sure they're both VA panels and look great at the store (they don't appear to have any of the defects talked about in the many threads I've read). I also have a vision problem (left-eye is pretty much shot), so the bigger the screen, the better for me. My wife laughed at me and wanted to know wtf I was thinking when I got my 23"s after using a single 42" for years.
