I was recently at Frys where I saw one of these bad boys and decided to buy it!
First of all, this case is a bit different from the pictures and reviews of it I have seen online. Here are a few pics: (Please ignore my messy living room.
This is a shot through the side of the case, which is mesh. I don't usually like the look of UV lights with case windows, although I think it may looks kinda neat through the mesh.
The mobo tray is removable, and can be switched from ATX type A to ATX type B (BTX?) easily. No screws are required, it is just a matter of flipping some latches.
The side has a removable door with brackets allowing for the mounting of 4 80mm/90mm/120mm/140mm fans.
Here you can see the grill on the bottom of the case.
My PSU and mobo look tiny in this case!
Here you can see the unique power and reset button, some USB ports (there are more on the front as well as headphone/firewire) as well as one of the built in carrying handles.
I do not have all of my hardware in yet (especially since my vid card is still not back from being RMAd) although I have found that the front (which allows for 9 drives) gives me ample room for DVD drive, 2 hard drives each in a 5 1/4" bay, and a 240mmx12mm rad. I've gone ahead and ordered a NB water block since the one on my DS3 gets hot as hell.
I cannot emphasize enough how HUGE this case is! My previous case (Ultra Microfly) makes this one look particularly cavernous. The construction is spectacular; nearly everything is toolless and all the metal parts are aluminum.
Feel free to leave questions or comments.
