Black coolant?
Obiwanshinobi900
So my mix goes as this for coolant: 90% distilled water, 10% antifreeze, some algeacide and some iodine. How does this sound?
I was thinking since all the lights in my black case are going to be white, I should have some sort of black coolant. I have used highlighter ink in past coolants to make it a neon green, but I was wondering how I could go about making it black?
Maybe some black ink from a pen or a marker or something?
you can get india ink at just about any art store but I don't know what it will do to your parts, Go with nightwalkers idea, if they make a black dye for water cooling then that would be the best bet.
I already have masterkleer tubing I spent about 20 bucks on. And I like the looks of clear tubing with a different colored liquid in it.
Get a bottle of india ink.
Black ink? Seriously? Have any idea what heated ink does to copper with prolonged use? In the short term it will stain it, and in the long run it will form a film that will reduce your effectiveness of your blocks.
+1 for Black Feser 1 non conductive coolant. Good stuff.
