Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
you can also do it the el-chepo way and just get some car tint and put it on the back of the plexiglass. Also lets you have the option of changing the degree of tint.
Just be careful using tint, and make sure you read the instructions well. Some of them don't do well with plastics, and will fog the plastic over a period of time, which would really make the window look bad (and likely break your heart, since you spent so much time on it).
If you're using the "H" style trim on the windows, you should be able to use glass, versus acrylic. Just get it custom cut at a glass shop, and you won't have the fogging trouble.
I hope to eventually make my silver dragon case into a black case with black acrylic front and side window. The front panel would be a bitch but damn it would look great.
I'd need really thick acrylic though, probably 3/4".
The place where i get my acrylic from is International Plastics. Check your local yellow pages you might have one local. They have all types of acrylic.
