Bizarre multi monitor problem - HELP!
MegaRouge
Here's my setup:
Radeon 9800 Pro
Viewsonic P95f+ monitor (primary)
PSOne LCD (secondary), connected via TV Out on the Radeon
This all worked just fine when I had it connected on my Ti4200. I upgraded to the Radeon and it's been problems ever since. I reinstalled Windows when I upgraded, installed the newest Cat's (4.7 at the time), plugged in the LCD, and it worked fine once I set it all up. Then, for no reason I can determine, I started having problems. Intermittently, the computer would not detect the LCD when I booted up. I'd get to Windows, and it would be turned off. I'd have to go to the advanced properties of the Cat's and turn on the TV out, then enable the secondary monitor in Windows display properties, then drag it to the right position just to get it to work, every time I rebooted. Pretty annoying. Then, it just started working again this morning, for no reason. I could reboot all I wanted and it worked fine.
I just installed the new Catalyst Control Center this morning. Ever since I did that, the secondary display now won't work at all. The CCC sees the LCD, sees it at the right resolution (640x480), but when I click on it it tells me it's not enabled. I enable it, it says it worked, then I click it again and it asks me if I want to extend the desktop to it, I say yes, and it goes right back to being disabled. For a second, after about 10 reboots, it detected it and showed an image then it turned right back off again. I can't get it to show anything at all now.
Here's the screwiest part - if I unplug the LCD and reboot, Windows still detects it as being there in Display Properties. I think that's the root of the problem. I even fully uinstalled the CCC and the 4.8 Cat's and reinstalled them after using Driver Cleaner, and it had no effect.
I know this is a bit long, and might not make a lot of sense, but I think the root of the problem is that Windows always thinks the LCD is connected, even when it's not. Any ideas how to stop that?
