TechLarry
RIP [H] Brother - June 1, 2022
- Aug 9, 2005
Ok, I'm stumped...
Running Vista Ultimate. For some reason, several of the HTTPS sites I access will not load in IE.
But some do.
These are corprate sites so I can't really provide examples unfortuntely.
I had the same issue with XP.
I have no software firewalls. No third-party Spyware apps running.
Funny thing is, if I load up VPC, and try to access the sites from there (on the SAME computer), the sites are accessible fine.
The only common item I can think of between the XP and Vista loads where the issue exists is NOD32.
The VPC host has SAV instead of NOD32.
Is there something in NOD32 that can block access to _certain_ https sites?
But some do.
