BIX vs JR-120.
Eklipto
If anyone has tried both of these can I get an opinion on which is the better radiator?
Also, it seems the BIX has mounting holes for a 120mm fan on at least one side. But I was looking at the JR-120 and I dont see any fan mounting holes at all, are there any?
Also, does anyone know if either of these will be able to fit under the 3.5in cage of a Lian Li PC6X without any modding to the 3.5in cage(just removing the rails riveted to the bottom/front of the case)?
Thank you.
