Ok, I am having trouble finding a working port forwarding/triggering setting for my router.
My GF uses alot of BT on her machine and it is behind my router not in DMZ.
Now I have tried forwarding a single port and also a range of ports and it makes no difference she is getting firewalled speeds.
I turned on upnp for a bit just to see what BT was going to do, and it setup WAN ports 1722 to lan port 6969 and that worked and gave her full speed, however I do not want to use upnp. I want to be able setup a manual rule and have it work.
I am wondering what settings/ports you guys have been successful with.
Also, if I try to create that same setting (1722/6969) manually, setting from to 1722 and "to" to 6969, what do I set in BT? 1722 or 6969?
I also tried setting trigger port 6969 and triggering range, say... 6881-6891, but that did not work.
Anyway, any help would be appreciated.
BT seems to be the p2p app that is the most sensitive to this stuff. Any other p2p app seems to work fine with just a simple straight port forward.
