Bitspower O-rings...where can I get them?
techboydino
Does anyone know where to get the bitspower o-rings part# BP-ML-O10-BK. These are the internal mulit-link adapter o-rings and are slightly smaller than standard G1/4 rings. I found them on their site but cannot find a way to order them. Thanks.
Fits inside these
Why not just take one to the local hardware store plumbing section and match?
currently that is the option. i wanted to try and get the exact spec ones since those are the only thing keeping the hardlines from leaking. probably going to end up doing that since i cannot find anyone that carries those.
Sidewinders. I advise calling Gary. If its available he'll get it.
