Bits?
dquez9
What's the difference between 128-bit card and 256-bit card? I trying to decide on a new vid -card.
The "bits" refers to the width of the bus between the memory and the GPU. A 128bit data bus is less desireable as it is narrower and therefore slower than a 256bit bus. So for the best performance, higher is better.
Thx, that's what i figured ..just confiming.. :)
