Bitfenix Prodigy "Mirror"
ArtX38
Systems:
BitFenix Prodigy (white)
Gigabyte GA-Z77N-WIFI
Intel Core i5-3570K
Corsair Dominator Platinum 2 x 4GB
EVGA GeForce GTX 670
OCZ Vertex 4 128GB
WD Red 3.5'' 2TB x 2
OCZ ZT Series 650W
Water systems:
Watercool HEATKILLER® CPU Rev3.0
Watercool HEATKILLER® NSB Rev3.0
Watercool HEATKILLER® GPU-X³ GTX 670
Phobya G-Changer 120mm
Koolance 240mm 30-FPI Copper
Laing DDC-Pumpe 12V DDC-1Plus
Phobya Laing DDC top Black Nickel Edition
Phobya Balancer 250 Black Nickel
Phobya Temperature Sensor In / Outer Thread G1/4 x 2
Koolance Nozzle Single, 3/8" (10mm) G1/4 Angled Threaded x 3
Koolance Nozzle Single, 3/8" (10mm) G1/4 Threaded x 3
Masterkleer Tubing PVC 13/10mm (3/8"ID) UV-reactive Black
Masterkleer Tubing PVC 13/10mm (3/8"ID) UV-reactive White
Mayhems "Aurora" - Supernova Coolant
Other:
BitFenix Spectre 140mm Fan- white
BitFenix Spectre 230mm Fan - white
BitFenix Spectre 120mmFan - white x 3
NZXT 24-Pin ATX
NZXT 4-Pin ATX12V
NZXT 6-Pin PCIe x 2
Aerocool Touch 2100 Panel
RGB Led (60 Lighting effects)
Video
BitFenix Prodigy - "Mirror" effects of light (without a mirror) -- patr 1 (light / dark (day / night))
BitFenix Prodigy - "Mirror" effects of light (with a mirror) -- part 2 (light / dark (day / night))
http://www.youtube.com/watch?v=ybZpW182e3I
http://www.youtube.com/watch?v=-yG5s4WYKCA
DRJ1014
This has inspired me to do another build. Havent had a build in over 5 years. This is amazing.
Pretty simple yet cool mod. When I pick up a Prodigy I may have to try something like this
Posted from Hardforum.com App for Android
OP20
screw the pc, i want to see what the rest of that room looks like!
SpeedyVV
The best case mod EVER!
What did you use for the side and front panels?
ArtX38
NEW Bitfenix Prodigy "Mirror" black_blue:
System:
BitFenix Prodigy Midnight Black
EVGA Z77 Stinger
Intel® Core™ i5-3570K Processor
Kingston HyperX 8GB (2 x 4GB )
WD Red 3.5'' 2TB SATA3 64MB IntelliPower
SSD OCZ Vertex 4 128GB SATA3
Corsair HX 750W, 80 Plus Gold
Phobya Touch 6 Controller
Corsair Fan Air Series SP120 High Performance Edition
Scythe Slip Stream Slim 120mm 1600rpm
LBM-x4 series LED Module
RGB LED Strip
Water systems:
Koolance tubing 13/10mm (3/8"ID) UV-active blue
Koolance Liquid Fluorescent Blue
Black ICE Radiator GTS-Lite 120
Black ICE Radiator GTS-Lite 240
Artx, you are a genius. Is there *any* way you can make a build guide (specifically for the black/blue)? I see the part list, but a guide to help us create something that magnificent without screwing it up would be amazing.
:D
-HP
ArtX38
Cool video. Still looking for step by step build if you have it.
Assembled in parallel BitFenix Prodigy white original name "BitFenix Prodigy Mirror Infinity".
When the project is completed show you a pictures with detailed changes
(Sorry but I badly speak and write in English, Write questions correctly)
ArtX38
Bitfenix Prodigy custom VS InWin radically designed new ( Computex Taipei Jun 3, 2013)
0_aefab_d448aea6_orig
0_aefac_eb5e4a61_orig
iamwhoiamtoday
That is an incredibly clean build, I absolutely love it. Sleek, concise, and has flair. Not to mention.... glowing computers perform better. Proven fact. :D
I thought it was a render at first it's so clean. Very nice job. I watched the video and I see you used glass for the side panels. Every think about using Plexiglas? Lighter and less concern about shattering.
