BitFenix new Mini ITX Lan-Party Case
Alai
I don't understand how BitFenix expects us to use all that hard drive space when mITX boards have only 4 SATA ports. Is there a mITX board that I don't know about that has alot more?
We don't. We give you the flexibility to use the case however you like. Some boards have a total of 6, and then if you use a pci sata card/RAID card, etc, you can get more.
On the flip side, you can remove it and use it as a high end gaming system.
encode
The "Diablo" build:
Intel Core i7-3770K @ 4.7GHz (Prime95 -> 81C)
Corsair H60 + CoolerMaster XtraFlo Red LED PWM fan (2200rpm)
Asus GTX670 DirectCU II OC
Asus P8Z77-I DELUXE
G.Skill RipjawsX 2x8GB 1600MHz (1800MHz O.C. with same timings and voltage)
Corsair Force GT 240GB SSD
Corsair TX650 V2 PSU
BitFenix Prodigy Black case
BitFenix Spectre Pro Red LED 230mm case fan (undervolted via included adapter)
attachment.php
attachment.php
attachment.php
:D
Can someone tell me if the Seasonic X-660W will fit this case?
Also, have recent versions of the Prodigy fixed the issue of the flimsy legs? I'm afraid my case might start tipping base on some of the reviews that I've read. lol!
KrylonArt
Does anyone have any photos of the case without the case feet and handles, but all other components on (front panel and sides)?
