dammit i only have one pci-e slot coulda sworn i had 2... well any advice on what i should get for bit coing mining with a budget of $800? should i get 3 7950s or 2 7970s?
oh and will this power
http://www.pcpower.com/products/description/Silencer_Mk_II_950W/index.html
a GTX 670 and 2 7950s/70s
Get three 7950's since they are getting relatively cheap (~$300). You'll get more hash rate with three of them versus two 7970's.
As for the PSU question, you can power a GTX 670 and two 7950's or 7970's. I have two 7970's and one 7950 with my main rig and it barely breaks 600w at the wall. Mind you I also undervolt which saves quite a bit on electricity and also heat.![]()
do you just run games on all of them or do you mine on those 7970s? also you dont need drivers to mine right? wouldnt it cause a problem if i have CCC and nvidia control panel on the same pc?
Has bitcoin rates come back up to profitable levels? I remember looking at it awhile back and so many people had flooded in that it dropped the value WAY down. I'd love to be able to drop coin on a 4-5 card 6950 and leave it bitcoining in the basement 24/7 if it would generate useful levels of passive income.
