visibiliti
- Apr 14, 2011
I got myself a 2nd 7950. I currently have some weak 500watt PSU in my case, so I am powering the 2nd card through another power supply with a paperclip to turn it on. I installed the 2nd card and I can't seem to get it to work. I have reinstalled the drivers, but other than that I'm not entirely sure where to start. The card doesn't appear anywhere in Windows. I don't see any options in my BIOS for the PCI express slots. I've tried reseating it multiple times. I'm wondering if for some reason jump starting the PSU is the problem? the fan on the card spins up when the computer turns on... All cables are tight, card is snapped in. Really not sure why this isn't working...
When dealing with multiple cards I found that I had to do things in a very particular order.
Basically, try uninstalling all the AMD drivers completely, and having 0 cards plugged in. Boot the computer like this, make sure all AMD drivers are gone, it should revert to the onboard stuff to get your monitor working. Then, turn computer off and plug in all 7950s. Boot the computer like this and THEN reinstall the AMD drivers.
I don't know why, but if I tried installing the drivers before plugging in the 7950s (my systems use 3, personally) it would always mess up and not detect them correctly in device manager.
