No, I'm pretty sure she knew what I was talking about. She didn't look confused... she actually said, "no but we have the Haswell iMacs".
She didn't mention they have Haswell Airs?
Went into the local Apple store this evening... asked if they had any Haswell MBPs in. She opened her mouth, then audibly shut it, and said no, just the iMacs... so something is afoot.
I'm right there with you.
I almost bit on the Macbook Air after the Haswell update but I can't take the resolution after seeing the rMBP.
I'm tempted to upgrade but I have a 15" so it seems like it might be only a sidegrade at best.I have a 2012 13 rMBP and Haswell 13 rMBP and I must say the difference is very minor in day to day use. I would not pay the difference to upgrade.
I get really good battery life on both, 8+ hrs, and with Mavericks I have never had UI sluggishness or issues.
Download Retina Display Manager: http://www.reddit.com/r/apple/comments/vi9yf/set_your_retina_macbook_pros_resolution_to/I've been using this dedicated gpu 15" MBP for a few weeks now. The retina display has more vivid colors but otherwise its a disappointment after the 17" screen. Too little real estate, even after scaling the screen to match 1920x1200. Probably the smaller screen size makes it feel more cramped even though the resolution should match the old one. The default 'retina' setting is just retarded you get like 2 letters and then you need to scroll already
Battery life is good and the thing runs much cooler than the old 17" from 2011. Also the SSD is a nice bonus. Otherwise I was a bit underwhelmed on the package you get for 2600 euros.
