Bit on the H50...
BioInclined
DISCLAIMER: I did search and have read on different ideas/fans. I am new to this forum but not the concept. That said, i do appreciate your time.
So i went for the best buy deal and got an H50 at $40. I have a stock AMD cooler currently so anything should be a step up.
I know that push/pull and exhaust out compared to intake(into case) show only minor differences.
I would like to change the fan on the H50 just because, i would like a bit more noise elimination. If i have to run 2 fan in push pull so be it.
I don't care much about LEDs or color. I would like to stay under $15 a fan so i understand i pay for what i get. I have been eying these.
http://www.xoxide.com/enermax-tbsilence-120mmledfan-blue.html
http://www.xoxide.com/enermax-t-b-apollish-120mm-blue.html
http://www.xoxide.com/gelid-120mmsilentcasefan.html
Now from my understanding, I want a thicker fan, 26+mm? up to 36mm~?
Not that it matters, but i plan to cut some extra vents into my case, top and extend the bottom side vent, this is my case.
http://www.newegg.com/Product/Produ...m_re=coolermaster_case-_-11-119-115-_-Product
wow, 55mm, i never realized they went that high.
I don't mind push pull, look or setup, it just seemed it wasn't worth it.
I did look for the Typhoon, but they are hard to find these days?
Either way, thanks guys, I'll be deciding within a week or so.
