domoMKIV said:bip is cheap and it works.
pro + pro = ftw.
taqueso said:I have not used either, but am planning on buying a black ice radiator in a few days. I had considered the Thermochill radiators, but there is a large difference in the thickness of the PA and BIP. The Thermochill PA120.2 is 59mm thick; the Black Ice Pro II is 25mm thick! My application is a SFF PC, so space is a premium concern.
Correct.theseeker said:I assume you mean cheap as in price?
{NcsO}ReichstaG said:I can't understand why anyone would consider to spend ~$130 on a PA.3 when a BIP.3 can be had for $30 @ Directron. The difference in temperature at best is a couple of degrees.
At that rate, why not buy 2xBIP.3 and another D5 for for about (total) ~150. It would surely yield much better temps than one expensive Thermochill radiator ...
