BIP III or Double Heatercore
GFreeman9
Ok I'm looking for a new radiator... currently I use a BIP II and it works pretty well temps: CPU (28C idle 38C load) and GPU (<31C idle and 34C load) the only problem is my system is pretty loud. I'm pretty sure I the BIP III will let me able to turn down the fan speeds a little. Although I dunno if the heatercore can do the same thing with two fans. Help is appreciated, I don't really care about an explanation much. Just please tell me which is the better cooling solution?
