BIP big enough for chipset,gpu,cpu?
capnstabn
This is my first WC setup and I am going with a BIP. Is that a big enough radiator for chipset,cpu,gpu? Also is the eheim 1048 pump going to move the water well through all of this?
I'm not a complete expert on h2O setups...but I've built a couple, and talked to a number of people around here that I would clasify as experts.
The pump should be fine, but I'd look at either a pair of BIP's or a 2x120mm BIP...especially with that X1900 in the loop.
The 560es in my sig should be putting out a fair bit more heat then your Opty, but regardless, with the cpu/gpu/chipset in my sig it's been recommended multiple times to myself that I go with a pair of BIP's or a BIP2...so I'd definitely think about it if you're serious about this.
If there's no way you're going to fit a BIP2 or a pair of BIP's in your case then you're not going to completely screwed. My last h2O setup consisted of a DangerDen TDX for the cpu, a Maze4 for the GPU, a single 120mm DTek heatercore with a ~80cfm 120x38mm fan, and a fairly small 12v...and I was able to push my 3.4E up to 4.3GHz and voltmod my X800XT-PE and run it artifact free up to 702MHz...obviously not the same as what you'll be working with, just wanted to make sure that you knew that even with a single BIP you'd still be in fairly decent shape.
depends on your noise goals. you can get enough out of a single rad if you move enough air through it.
however, if noise isn't an issue, i'd really wonder why you would choose a 1048 pump, which is really quiet but doesn't perform as well as similarly priced DC offerings like the dangerden D5/swiftechMCP655. a stronger pump will let you get more out of your block and rad, whatever ones you choose to use.
if you are shooting for quiet opperation to complement a 1048, you should be shooting for a triple rad ideally, a double at the least.
have you looked into the swiftech radbox for mounting a double or triple rad, without excessive modding of your case?
just as an aside......i think that you should invest in a decent PSU WAY before you should be looking at a luxury like watercooling. i don't care if it's rated by raidmax for 580 watts, it's still a raidmax, which is to say: to be avoided.
Awsome advise all around man, on the watercooling and the PSU. I completely agree about the Raidmax comment.
Thx DFI, you are one of the folks I was commenting on that I refer to as being "experts" on watercooling, and it's nice to see you joining in here.
capnstabn said:
Thanx for the info. I will check out those mounting brackets.
Hope you find what you need, I was looking at them myself to see what was up, but I've recently decided to pick up the Lian-Li PC-7B, and I'll most likely just be setting up a 3/8" h2O loop with a pair of BIP's...making perfect use of the cases front and rear 120mm fans...keeping the look of the case/h2O setup very clean...and giving me the ability to keep the entire setup internal.
that sounds good but i personally wouldn't do that .. the bips will very much reduce air flow and the air coming in will be warmed ... + you'll have a lot of extra tubing
what about a bip2 in the top ... i've seen that done many times with the pc-7s and it looks nice and would probably work much better...
not tryin to tell you what to do just tryin help ...
OP: i had a bip1 with an apogee , maze 4 gpu, and D5 pump and it struggled ... i upgraded to a bip3 .. www.directron.com for bip2s and 3s for 29.99 + shipping..
mal out
No offense taken at all...I appreciate any input I can get whenever I'm leading up to a case mod of any type.
I'd have to measure things out though, because I'm really hardset on having the entire h2O loop located inside the case...and if the BIP2 will fit up top between the PSU and the front panel then I'll go that route for sure.
malicious said:
Page 4 for me...but thx bro.
I had completely forgotten about your Angel, being that it was while ago...but that's just what I needed to see. The only thing is that it will limit my PSU size...so I might end up going with a PC-70(77) so that I have more room to work with. At least with the PC-7077 I could use a BIP3 with ease. :D
