biostar? usb headers
antok86
how many usb headers does the biostar tforce939 have?...i have one connected to the front usb on my qpack....is there any more i can use ....or possibly get a splitter for the jumper to plug more than 1 ....???
There are two onboard header pinouts, each of which supports two USB ports.
So, in other words, you have another two USB ports on your motherboard.
http://www.shop-intel.com/shop/product.asp?pid=SIDB8341
Just give a look over on your motherboard since you own it. Whatever you plugged in the original usb headers into...if you find the same lookin' thing, that's your second header. I know for a fact that the 754 version has 2 so your's should as well. Prolly one around the power headers and another around the pci slots.
