Biostar TP I45 Crossfire?
Monolith2013
Quick question... Do I have to alter any of the jumpers for Crossfire mode if i'm using 1, HD 4870x2... IE, it's only using 1 slot... So do I still have to align the jumpers for Crossfire mode?
Edit: I tried doing this a short while ago... setting the jumpers to x8 x8 instead of x16 xOff and now it's jumpier in games... So i'm thinking that one of the GPUs isn't being accessed... Any thoughts?
For one slot, you should set the jumpers to give your card the full 16 lanes. Setting them to 8x/8x mode will cause the slot with the X2 in it to run at half the bandwidth, which is probably causing your jerky performance.
Yeah, that's what I figured, but then again, the 4870x2 is a crossfire solution, so I guess part of me was wondering if it was only accessing 1 of the GPUs at x16 and not using the other one... At any rate, I just tested it to see what would happen. I'm still having issues in Far Cry 2 though... I've got really low fram rates so i'm thinking that one of my GPUs insn't being utilized... Wondering if it's a driver issue or the card is messed.
