Biostar TForce 6100 - 939 Highest HTT
Farmergoo
I was just curios what HTT you guys have been able to get out of this board. Im getting an opty 165 that has 9x multi so i was just wondering what I can expect out of this board in terms of overclocking.
-Make sure you post what bios your running
So far 257fsb for me and have tried all three bioses. :( Not looking good! I am not sure it's a board deficiency, but that Watchdog preventing the board from booting. It will not post with a MHz higher than this.
Guys please include this info, because I am curious if this is due to a weakened board revision:
FSB: 257fsb
CPU-Z: Chipset Revision A2 (under "Mainboard" tab)
Board: Revision v1.1 A03 (written on board)
Edit: I'm currently priming at 310fsb after using the OC utility - smooth as butter to increase. Allowed jump at startup straight from 200fsb -> 300fsb! I would rather not use a utility, but losing 3MB of memory is a worthy tradeoff. 315fsb seemed to be about the max stable before I just put the case fans back on. However, it's cold as snot at my place and I put AS Ceramique on both the northbridge and southbridge cores, so this is probably the high end.
Sleepeeg...
I'm on Bios B02, the one Mr Busta Posted.
Chipset Revision - A2
Board revision - Dunno til i take this rig to bits again...
I can get occasional booting at 250, have had 283 with the windows overclocking tool...
I want the original shipping Bios as i reckon that one would get me further without this watchdog thing....
Dubz
