Panther5060
- Oct 26, 2005
Ive decided to make a real thread for this as itll be easier for people to see...
are there any bios modders in these forums?
if so, i have found that after updating to the latest bios for my TForce 6100-939, I can't lower my CPU multiplier below the normal multiplier level. I have also found that my HTT setting will only go to 4x or 5x and setting it to 3x, 2x, or 1x will revert back to 4.
If there is anyone on these forums that could fix this, could you help a guy out
Prior to bios flash (I can't revert as, surprisingly, my old bios file is corrupt)
A64 3000+ E6 Venice @ 2.72GHz @ 1.518V @ 8x Multip.
340MHz HTT/278MHz dram @ 5:4 ratio 2.5-4-3-6
Now:
A64 3000+ E6 Venice @ 2.64GHz @ 1.442V @ 9x Multip.
294MHz HTT/240.5MHz dram @ 5:4 ratio 2.5-4-3-6
(note: the HTT is running at 2352 as verified by CBI and Everest... kinda sorta having problems here)
As you can see, I'm taking a huge performance hit and running the HTT way way out of spec, if anyone can help please do.
Link to bios:
http://www.biostar.com.tw/t-series/...wnload_bios.php
CU51MA20
***EDIT*** I have tried flashing the bios using both the windows tforce bios flasher and a bootable cd... neither resolved the problem and I am still stuck at 2352 HTT...
god floppy drives and bios' are the biggest pains in the... to deal with
Now:
Link to bios:
CU51MA20
