Biostar TF570 SLI
jlqrb
I have been overclocking on this board and it does pretty well but when ever I change anything out it resets the cmos back to defaults. This happens even if I remove a USB cable I have pluged into the back.
I was wondering if anyone knows if there is a way to chage this so I don't have to restore my settings everytime I make a small change.
Thanks
I just flashed to the latest bios from Biostar for the board and I am still getting the same issue. I have also tried a new battery and made sure the jumpers were all set correctly. I get a message that says something about floppy drive error 40 and checksum error. I don't have a floppy drive in the system.
Make sure you disable the floppy drive then, honestly I don't really know. What fixed it for me was a BIOS upgrade if that didn't fix it for you then :confused: But make sure to disable the floppy drive in the BIOS.
I do have the floppy disabled. I have been reading that it could be a failing PSU but my PSU never given me any other issues but I will switch it out and see if that helps.
