Biostar TA790GX 128 Help,
donnydorko
I cant seem to change the cpu/htt frequency with my biostar in the bios.
I have to use amd overdrive in windows to up it from the default 200 for my overclock.
Anyone know why when i press enter on it in the bios it doenst come up with any options? am i missing something. It is not greyed out and i have it on manual overclock settings so you can change settings.
Thanks for any help.
check and see if there is an advanced thing.. also check to see if there is a new bios out.. possibly will fix the issue..
Same problem here locked at 200 in bios clicking enter does nothing. Running 940be at 3600 still learning what all the settings do before i try to push it harder.
figured it out, i just typed in a number and it entered it, try pressing the + sign also.
Hope thath elps anyone,
