soulsaver_8229
- Mar 17, 2005
Ok, i think my biostar shuttle is overheating, shut off on me half way through LoTR's
anyhoo i heard if you can not keep your hand on the hottest spot of a comp longer than 10-20 seconds then its over heating? didnt bother looking at temps but it was over the warm type temp, its a oc'ed 2.0 (1.6) durron, 9500 np, 1 gig mem, 80 wd hd, curious if i could just put it on higher feet? it only sits like half an inch off my wood table, or should i de clock it or find a better proc? any tips/tricks to help would be helpfull ty
soulsaver_8229
soulsaver_8229
