I just wanted to write a short review of this little guy because I could not find anything out on the interwebs about it prior to purchase, so I took a chance and just went for it. Here is what was put together....
http://www.newegg.com/Product/Product.aspx?Item=N82E16856115033
also a 2gb stick of 200-pin SODIMM 533 from Crucial.
FreeNAS 0.7.1 loaded on this setup as the boot drive......
http://www.newegg.com/Product/Product.aspx?Item=N82E16820191094
http://www.newegg.com/Product/Product.aspx?Item=N82E16812186050
plus two 1TB SATA drives i had already.
What I needed was a NAS with dual GigE ports with jumbo frame support. I was originally looking at either a Synology or QNAP box, but what I built is cheaper, more robust, has more options (at the slight sacrifice of Synology's nice pretty web GUI, but if you know what you are doing with FreeNAS it does the same things and more), and has an additional PCI slot for either an upgraded RAID card, PCI video card for use as a HTPC media center, or whatever else you think of. FreeNAS detected/had drivers for everything right out of the box.
This Biostar box has an intel Atom 330, dual core @ 1.6ghz. Coupled with 2GB of RAM it will max out your TCP connections before maxing out the processor/RAM. The Bittorrent client runs great, and FreeNAS also enables you to use IP filtering lists like peer guardian along side it if you need that sorta thing, which is not available with most other NAS boxes. You can also have this act as a hardware firewall or internet gateway, web server, media streamer, iSCSI target, etc. The thing boots between 5 and 20 seconds due to the compact flash boot drive which is nice. FreeNAS takes under 100mb of space so a 4GB CF drive is overkill. The onboard video is sufficient, but dont expect quality video playback of any sort. The onboard sound is actually pretty good, but its only analogue so I wouldnt rely on this for HQ sound to a home theater or anything.
Network throughput is as good as you are going to get for under $1k. My network might be a little more overkill the most peoples.... all Cat6 cable, every computer has dual GigE ports, aggregated; one going to a GigE router running DDWRT and connected to the outside world, the other to a GigE switch, the router and switch are linked to each other over another GigE uplink. All interconnected nodes have 7k jumbo packets enabled. I am not using RAID on the NAS currently, so network speeds are limited only by the speed of the hard drives themselves. I havnt done extensive testing so I wont throw out an exact number, but write speeds are similar to what they would be if the drive was hooked directly to the PC, minus 5 to 10% or so for network overhead.
PC to PC transfers of a 4GB zip file over the network are in the 200mbytes/sec range (that is using virtual RAM drives as targets on performance computers, trying to make the bottleneck be the network as much as possible {and I still dont think it was fully saturated!!}, otherwise it would be hard-drive-speed-limited again). Transferring a 4GB zip file from the NAS to a PC uses about 2-5% of the NAS' CPU power and not much RAM at all, that is with 7k jumbo frames.
All together it cost me $350 not including the two hard drives already on hand. That is a savings of $50-300, depending on what you look at, for a similarly performing network storage box. You can even cheap out some more on the compact flash drive portion and save another $50 or so. The only thing I wish it had was room for 4 hard drives instead of two, but two is sufficient for me. When I run out of space il throw two 2TB drives in it, I dont think me and my friends will fill that anytime soon. If you dont need extensive RAID options, but want everything else and to save a bunch of money- this is the box to get.
