biostar ideq 210p
will a ati x800 xtpe video card work in one of these is the power supply big enough and how about the hea problem its only going to have a amd64 3000+ with a gig of ram
The 210P has room for my 6800oc and if that is a card that takes up 2 slots it will work also, the VGA slot is inside of the 1 pci slot so you are good to go no matter what, and i have the 3000+ and 1 gig of pc3200
ok next question i want to put my audigy2 card in there also but it sits right next to the video card fan will the video card stay cool enough or is the onboard sound good enough
the temps will go up a little bit but that is obvious because you are restricting some airflow and you have to expect it to go up. However you should still be perfectly fine. It is pretty much just like putting those two cards in a normal case right next to each other so there really isn't going to be any problem.
That is true. mine doesnt over heat or anything runs a little high like 45c after a ffew hours of UT2k4 and CS:S i have an audigy live 24-bit next to mine and only 1 fan on my video is exposed and i havent had one problem.
Lordnikon
Off topic a bit but what RAM are you using? My roommate has a 210p and is getting lockups and we think its a a RAM compatablilty issue.
Thanks.
