Biostar 965PT IDE Problem
clague
I am having trouble getting my pioneer dvr-105 to write cd's or dvd's. It reads them fine and dma is working, just can't write. I've tried the latest driver off the cd, which is the same version thats on via's website. Any help or ideas would be appreciated.
Are you sure the discs are compatible with the burner? Newer firmware available for the drive? Can you use basic microsoft IDE drivers rather than Via ones?
Yea, I tried all that. When I put the drive on a USB adapter it works fine. I tried updating the firmware while it was on IDE, but it would not work. I was able to update the firmware using my USB adapter, but it still will not work on IDE.
So you don't think it's a driver problem?
I think it might have something to do with the VIA IDE driver. But what, I'm not sure. I was hoping somebody else might have run across a similar problem with this board.
Can you just use the generic microsoft IDE driver? Seemed to work with the IDE problems with Nforce boards.
2 things...
#1 NEVER use the Via IDE driver, unless you want problems.
#2 If you do not have the Via IDE driver installed, try a different ATA cable.
