Bioshock Mouse Lag
JustinSane
I get a lot of mouse lag in the Bioshock menus and whenever there is a cursor on the screen. Like when you have to hack the robots its pretty much impossible to do it because of the mouse behavior. Anyone else have this problem?
I had that problem in the demo but I don't own the full game yet. I thought it was just me. :eek:
I was getting a lot of lag until I turned off vsync. Off course, that means turning off vsync which isn't really ideal. I'm also using the nvida beta drivers, and I think someone around here said the previous version don't have the lag problem.
I've seen a few similar posts and one user pointed towards his mouse driver.
try uninstalling the drivers for your mouse (assuming you do have some installed) and see if the standard Microsoft drivers exhibit the same problem.
I'm using the beta 163.44 drivers and I've got vsync off, too. I don't have any drivers installed for me MX518 either.
any game i play, even if i get 150fps...Vsync lags my mouse, bad...so i never use it...and i dont notice tearing ever either...so ya
hey guys i found the fix for this, my hand was getting sore because of how bad the mouse lag was
change these settings in the Default.ini file, and it fixes it!
CaptureMouse=false
there are 2 of these so make sure you change em BOTH. Ctrl+F and type Capture. Change em both to False
For those running vsync with mouse lag, you must MAKE SURE you have triple buffering forced on in the driver settings. Also make sure it's enabled in game.
