Where's the 680 and 670 benchmarks if they're going to post 1x 7970 and 7950 results?
Also, no 7990 (Unofficial) or 7970 CF but instead 6990? Why not post 590 results while they're at it![]()
Only person who mentioned being mad was you.
Also, by that logic why not post 7770 results instead of 7970 if all we're looking at is architecture?
lol, it wont matter.
Also, by that logic why not post 7770 results instead of 7970 if all we're looking at is architecture? I guess we can then conclude that an ASUS ARES II performs the same as a reference 7950x1
Because its not the top card...stop nitpicking and bickering.
Well, I don't mind the Titan being there, but it would have been nice to see the GTX 680 since that is what competes with the HD 7970 (price and performance). And why is the 6990 there? That makes no sense.
That's all I was saying. The numbers are what they are, but wtf @ these comparisons. It's like showing us a 7990 benchmark vs a 680, then a 670... then a 590 at the end
FPS and frame times are intertwined. That aside, it's not any type of info that can be compared. It's still data, though.
Its showing frame timing, not FPS...all that really matters is single vs dual card configurations anyway.
Ok, so why use a last gen comparison for AMD but not for Nvidia?
Yeah they are, but not in a sense that we care about. We care about the magnitude of the spread of frame timing...not the actual timing between frames...so FPS really doesnt matter.
You are right, it's not in a sense that we should care about. It depends on how the data is presented though. I've read where people have walked away after reading comparisons between dual GPU and single GPU setups saying the dual GPU had less MS when MS is an AFR phenomenon. It was simply because they were faster.
What can i say some people are stupid. I dont see anything wrong with how this data is presented, but then again i understand what the data presented here is showing.
So AMD should be pulling shenanigans to make the games run worse on nVidia hardware? It's better for PC gaming that they aren't doing that.
I love how these tests are done on a 1600p resolution.
