Good Morning,
I purchased an Asus M4A78 Plus about 3 weeks ago and I have not been able to get it to work.
The problems I have encoutered are the following.
1- When I boot the PC it stays stuck at POST (initializing USB Controllers) but I do not have any USB hardware attached the MOBO. I have an USB keyboard which I replaced for a PS/2 keyboard when I first encoutered this problem and it still can't get past it.
2- It won't let me go into the BIOS at all, I press Delete to try to get in but it doesn't let me. It just stays at Initializing USB Controllers.
3- I tried several times to reset the BIOS hoping it would ask for me to load the default configuration or to press F1 to configure it but it doesn't work.
a) I tried to reset the BIOS by removing the power cord and swapping the CMOS jumper but it didn't work. It just boots normal and stays at initializing USB controllers.
b) I removed the battery for 5 minutes the first time, swapped the jumper and tried again, no results and then I tried removing the battery for 30 minutes and no results. It boots the same way and stuck at POST. Never asked for reconfigured the BIOS.
4- I tried switch around the RAM sticks to different slot positions just incase it was a memory problem. Nothing happened. I tried with 2 other brands of memory sticks and the problem persists. I tried with 3 different AMD processors that I have available and it didn't work. Now I'd like to mention that the Memory sticks, the CPU, video card and whatever I've connected to this MOBO, works perfectly on an Asus M2N-VM DVI that I currectly owe.
I'm out of ideas and I don't know what could cause these issues. I've been thinking maybe a bad BIOS Chip but I don't want to order a replacement until I get some advise on this. I can't RMA it because I'm overseas and it would just cost me too much to do it.
I've been a visitor of this site for over a year and this is my first post as an actual memeber (that email requirement thing really got me).
I'd appreciate any help and/or advise.
- Louis
- Louis
